How to download dvd cover animated gif?
How to download DVD cover animated GIF? On what website we can get a free download? I would like to get some sample animated GIF cover or some editable GIF images so that I can also create my own version and please do suggest a better application or software use on creating animated GIF format.
Thank you.
Answered By 25 points N/A #181571
Hello! Good Day!
If your professional enough, you can create animated GIF in Adobe Photoshop.
There is also software that is much easier to use than Photoshop to create animated GIF like:
• Smart GIF Creator.
• Easy GIF Maker.
• Blaze GIF Creator.
If you don't want to download and install this software, try these websites:
They are like an online GIF maker. All you have to do is just to upload your pictures, set some settings (Speed, Size and etc). Wait for the process to finish, then you can now download your .GIF file.
Hope it helps!
