How to download dvd menu maker at Nero Software Informer?
Hi Expert,
I am planning to download DVD menu maker at Nero software informer, but I don't have an idea how to download it.
Is anyone could try to help me.
Thank you.
Hi Expert,
Thank you.
If you are making a DVD with movies and a menu then this is what you need:Â
This software is easy to use it's mostly just drag and drop.
But if you're still not sure here's a video tutorial on how to use this to make menus:Â
To download DVD Menu Maker
1. Open the given link.Â
2. Select your software DVD Menu Studio and then open it
3. Click on ‘’DOWNLOAD’’
You can direct download by follow this link.
It will ask to download some tools with DVD Menu Studio you can choose ‘yes’ or ‘no’ and enjoy the day using this software.
