Hello guys,
How to download event viewer pro? I need a software that will monitor all my computer system’s event log so that I will be able to know the security measure and my computer daily transaction and to manage my computer in a way that to keep it away from viruses. Just share with me your ideas it will be a big help.
Thank you.
You can download Event Log Viewer Pro, which is a powerful tool that manages your computer. It monitors logs, reports, and events that happens on your computer system, such as security warnings, software, and hardware malfunction. You can view and export events that are logged in HTML, XML, CSV, RTF or Text formats.
Nelson
Event Log Viewer Pro – manage your computer expertly. It help you get Quickly browse, find and report on problems,security warnings and all other events that are generated within Windows. Easily identify hardware and software faults. You can downloaded from:
