How to download Facebook video call x64
I want to use video calling on Facebook but I do not know where to get it.
Please tell me how to download Facebook video calls x64 bit.
I am using Windows 7, is this important to install this?
Hello Jen,
The simplest way to do this is the following;
1. Open your Facebook Account.
2. You should be able to the Facebook's search bar .
3. Type in Facebook Video Calling.
4. You should now see the link to it.
5. Click on that link and download it.
6. Follow the simple steps and things should work just fine.
7. You should now be able to use the feature
There is another way and the simplest recommended useful trick to do this, here’s how;
1. Make sure that you're signed in.
2. Select an active Facebook friend from the chat list found right in your window.
3. The chat box now should appear. Now you will see a Video icon next to the name. Click it
4. This should prompt you to install Video Calling..
5. Install it and follow the instructions.
6. That's it.
Hope this helps you simplify the problem
You can perform video calling on Facebook by different ways. You can download Skype and install. Login to your Skype and connect to Facebook account. Connecting option is available there.
Facebook and Skype are working together.
Now pick a contact you want to call and click on “Video call”. The second option you can follow is login Facebook and click on chat. From the chat popup you will click on the contact.
Then click on the "Video call" icon in the upper corner of the appeared frame.
