How to download a file every minute.
Hi Experts,
I am using Mozilla Firefox for daily surfing and downloading files.
Now, I am suffering a problem with Mozilla, I am not able to download multiple files at a time continuously.
Can anyone help me how to download a file every minute so that there would be no problem in downloading multiple files one by one.
Best Answer by Marshall Kwak
Answered By 0 points N/A #164615
Hi Mark,
I am not sure of what you mean by “multiple files at the same time continuously”, “then multiple files one by one”.
However, by default, Firefox can download several files simultaneously.
You can check the download window under tools menu to see the progress of each file where you can perform other actions such as Pause or Cancel.
Alternatively you can visit where you will get direct instructions customized for your operating system.
Hope this will be of help to you.
Answered By 15 points N/A #164616
Hello Mark,
It seems you need a software to manage your downloads since you plan to download multiple files at the same time.
What I suggest is to use a download manager.
Flashget is one famous download manager in the market today.
With this program, you can download multiple times at the same time, you may also pause/resume downloads anytime you want.
The most important thing is that you can avoid corrupted downloads since Flashget continues the download where it left off in the event that your internet connection gets interrupted.
