How to download a flash text animation software Mac?
Hello experts,
How to download a flash text animation software Mac? I want a free download for this kind of application so that I will be able to learn more in the aspect of animation especially on the 3d grounds and fields. I hope you can give me the best software when in terms of quality and high definition rendering process.
Thank you.
Best Answer by Cristina McCormick
Answered By 5 points N/A #184773
There are various software available. But I would suggest you SWiSH Max4 software. You can download from HERE. Below are the some of the features of this software.
1)  It has a various new Effects.
2)  300 components or you can add your own custom built components.
3)  It has effects to make creating animations quick and easy.
4)  Full design control.
5)  Supports multiple overlapping soundtracks with various sound effects.
6)  It has various project Templates and Wizard Panel for quick publish.
Answered By 0 points N/A #184774
Hello Thimothy Raine,
Pleasure to help you,
You can find lots of sites to get Flash text animation through a Google search. One of safe site to get it for free is http://download.cnet.com/Supreme4-Components-Flash-Text-Effects/3000-2213_4-10595058.html
Or you can get it from https://en.softonic.com/s/flash-text-effect-software:mac
I am sure it will solve the problem.
Thank you.
