How to download flex raid?
Hello guys,
I tried to download flex raid but there is a problem occurred such as it do needs WMI as a requirement for the installation to go through. Now I just want to ask if how to download flex raid? The proper and secured way of installation can help me to get the application.
Thank you.
Best Answer by Dyer Pearlman
Answered By 15 points N/A #172846
Flex Raid is quite a powerful cloud solutions provider. In order for it to run properly, Flex Raid utilizes WMI to operate most of its functions. If you are encountering WMI issues upon installation, then refer to this link for WMI diagnosis:
You can also try to have a fresh installation of WMI tools. Just try this link for download, and then use it to reinstall your WMI.
Answered By 0 points N/A #172847
Hi Pamela,
You can download FlexRAID on this link http://www.flexraid.com/download-try-buy/
Once you download it double click the installer and follow the step by step installation process. Accept the terms, choose installation type, select destination folder and lastly create a  shortcut. When it is already installed, it runs on a web browser because it has a web interface. It is compatible with Chrome, Firefox and Explorer.
To launch it, use the start menu or the desktop icon and you will see the image below.
