How to download floor plan map for Mac?
Hello experts,
How to download floor plan map for mac?Is it possible for me to download that kind of software in my mac operating system? I am just afraid to make some downloads because of some viruses. Please do tell me the safest way to make a download.
Thank you
Best Answer by Galaline Samuel
Answered By 0 points N/A #149212
There are only few tools which can be used for the same. I have seen one small application which can be used for floor mapping or mind mapping in MAC. The tool name is called as OmniGraffle. This is the only tool which I have found. You can actually look at those and let me know if you are able to do the necessary things with this. You can actually download the same form the below link which I have provided.
https://www.omnigroup.com/omnigraffle/
I am not sure whether it is freeware or not. Please look into the product details from the above link to download and if it for sale see the purchase details.
Samuel
Answered By 0 points N/A #149213
Hello Brian,
It’s good that you want to protect your device from viruses/malware. The safest option would be to download genuine software from genuine sites; although it might be expensive to purchase the software but in the long run your sensitive information would be protected. Try the following websites for software that would enable you map your floor;
http://www.floorplanner.com/
All the best in your endeavors.
