I use Microsoft Office 2007 on my PC. I want to download some frames for word. I need some downlinks or some names of websites where I can find them. I also need to know how to insert those into word documents. Need some urgent help with this.
Thanks
How to download frames for word and how to insert it
There are free frames included on MS Word 2007. Just simply open Word 2007 and then click Insert> Clip Art and then type Frames on the search area. If you want to download more clip arts, you can download it from the Microsoft website stated here.
For creating a custom frames, click the link below:
http://wordfaqs.ssbarnhill.com/BorderArt.htm
Hi Geraldine,
There are many ways to easily insert frame into document in Microsoft Word.
First method is this, open Microsoft Word application.
Open you document into word application and click on insert in menu bar.
And choose your desired thing to insert in document.
2nd thins is to get help online.
To do so, I suggest you to visit the link below or try using Microsoft Office Word help center which can be found at the upper right corner of the window.
https://www.extendoffice.com/documents/word/733-word-insert-frame.html
Hope this helps.
