How to download free family feud game for android?
Hello there Laki,
Family feud is definitely a nice game for you to play. And yes you can try manually downloading it on your phone or you can also download it from your computer and transfer it to your phone. All you need to do is go to Google play's website here.
Download the game and save it to your memory card and access and install it on your phone.
Installing Android apps and games on your phone depends on the version supported by the app. If your Smartphone’s Android version is supported by the application or game then you can install that app. But if not, you can find other applications that are compatible with your device.
Family Feud Android game
If you want to play Family Feud on your phone, go to Family Feud 2.51.6 on APKPure.com to download the APK file. This version of Family Feud requires Android 4.1 Jelly Bean and higher. You can also download it on Google Play: Family Feud. This version is rated 12+ for Sexual Innuendo. Another one you can try is Family Feud Live! on Google Play.
It requires Android 4.1 Jelly Bean and higher. This is also rated 12+ for Sexual Innuendo.
1....
