How to download free flash player mozilla firefox android?
Hello experts,
How to download free flash player Mozilla Firefox android?
I want a download which is compatible to all android operating system in any kind of mobile phone.
I need a Mozilla Firefox browser and a downloaded flash player as well.
Give me some tips on how to get this done.
Thank you.
Best Answer by Emil Onoon
Answered By 0 points N/A #180840
Hi Davis,
The Mozilla Firefox browser is only available to the android phones which have a resolution of 800×480 or greater. So if you have any android phone which has this resolution, then you can download it from the Google Play Store.
Follow the steps to download Firefox and Adobe Flash Player.
1. Depending upon the version of your android OS, the Google Play app could be on your Home Screen or in your Applications folder. Tap it to open.
2. On the top right, in the search field, search for Firefox. It will show a list.
3. Tap on Mozilla Firefox to download.
Similar procedure is there for Adobe Flash also.
1. Search for Flash Payer in the search field.
2. Choose from the list to install.
And to know how it will play on Firefox, refer the screenshot.
Answered By 0 points N/A #180841
Direct Download Links:
Download Link for Mozilla Firefox for Android Devices
Flash Player is no longer available on the App Store, so you need to download the Archived version from the link below:
Archived Flash Player for Android Devices
To enjoy animations and watch your videos, you need to enable Flash. To do this, follow the steps below:
1. Tap the Hardware Menu button.
2. Tap More and then choose the Settings.
3. Under the Settings, tap the Plugins item and then select Enabled or Tap to Play.
Answered By 10 points N/A #180838
There are many links available for download flash player for your desired browser you can visit one of these sites to get your software:
Browsers and Plugins Downloads
Free adobe flash player
Download Adobe Flash Player
I hope you will be able to get your desired version also from these sites.
Smith Thompson
Answered By 0 points N/A #180842
The new version of Firefox named “Firefox Beta” which supports Flash on Android phones.
You can download “Firefox Beta” from the link given:
This version is compatible to all android operating system in any kind of mobile phone.
Building flash player is attached with this browser. There is no need to add external Flash player.
Thanks
