How to download free half life 2 to iPads?
Hello experts,
How to download free half life 2 to ipads? I would like to play half life 2 game in my ipad and I need a free download from the internet but I don’t know how. Give me some instruction on how to get the best download that is compatible with my ipad. Thank you.
Best Answer by Stacey Alexis
Answered By 10 points N/A #185732
First of all you need to check that your game is compatible with the system secondly check that the game full fills the requirements for the system you need to play on. The screen resolution and other things may vary in this case after that download game from network for the device you want to play on and enjoy playing game.
Smith Thompson.
Answered By 0 points N/A #185733
Hey,
You can download it from your PC. Just find the game on the internet, but you need to know that the game file should be compatible with your iPad. Write down the name and your own need on the search engine. You will get what you want to.
1. First, download the steam installer from the following link. http://storefront.steampowered.com/download/SteamInstall.msi. Then install it by selecting your broadband speed.
2. Now run the steam set up & create a new free account by entering the required details & allow “steam” to update your system settings
NOTE: To use the free offer you must create a new account
Otherwise, you can download SprayR software on your ipad from http://sprayr.software.informer.com/
And download Half Life 2 from http://half-life-2.software.informer.com/1.0/
I hope it works.
Thanks
