How to download free html codes multiple pages? Give me some website that allows a free download of sample codes of html. Any suggestions and ideas for tutorials about html will do.
Regards, Alisa Pitzer
Dear Friend! Its a very easy Job. You just adopt following steps to download all website information containing its images, its HTML coding of single and multi pages websites.
1. Install the software "WinHTTrack Website Copier".
2. Open the software.
3. Click "Next".
4. Give Project Name & Project category of your own choice.
5. Select the path where you want to download the Website.
6. Click "Next"
7. Now write the URL of your required website, of which you want HTML codes.
8. Click "Next:
9. Then also click "Next"
Website information has been downloaded in your mentioned Path.
Enjoy
If you want to know how a website was coded, the “View Source” option in web browser is pretty handy. It will show you the codes how that website’s page was constructed. Here’s how to do it. Launch your web browser then visit a website. Once the page loads completely, on your keyboard, press CTRL + U.
This should open a new tab containing all the HTML tags and other codes used on that web page. This helps you visualize how the website was constructed. But this is only limited to that particular page you opened, the codes that were literally written into that page. The “View Source” option doesn’t show the contents of other files linked to that page like the CSS and JavaScript files.
Another limitation of the View Source option is PHP. If the page contains PHP scripts, they will not appear in the View Source page. If you want to learn how to create an HTML page, go to W3Schools.
