I just purchased a new nokia mobile phone. And I want to download a free nokia free contacts editor. What is the step by step process on downloading and installing the said application. I want to know more about nokia applications please do share your ideas with me.
How to download free nokia contacts editor?
There’s no specific software which allows you to edit contact list on your nokia phone. There’s software which can help you to connect your nokia phone to your computer. It’s Nokia pc suite. If you want to edit you contact list on Nokia phone, you can simply download that software from the net, then you can try these steps,
1) Install nokia pc suite software to your computer.
2) Plug-in to computer with USB cable.
3) Expand it and you will see ‘Contacts’.
4) Select it, and then it will let you edit your contacts.
