How to download free ringtones for Skype android?
Hello experts,
How to download free ringtones for Skype android? My mobile phone has an operating system of android and I just downloaded a Skype to use when chatting with my friends, give me some suggestions on how to setup the ringtone to be downloaded as well.
Thank you.
Best Answer by Tracy Tamara
Answered By 0 points N/A #184851
Hi
Skype has ringing tone by default. I do not think there is option to download tone for Skype. You need to use same ringing tone. If you want to select particular tone for some contacts. Keeping on Skype you cannot do so. If your os provides such feature that apart check settings
Thank you.
Answered By 0 points N/A #184853
Hi Timothy Raine,
Yes, you can change your Skype ringtone, to change your Skype default ringtone follow these steps :
  • Go to var/mobile/Applications, then look for the folder that has Skype.
  • Go into the Skype.app folder and just drag in the desired .wav file.
  • Just make sure you renamed caal_ringing.wav.
I think, by following these steps, you can change your Skype ringtone.
