How to download free screen video capture mp4 linux?
How to download free screen video capture mp4 Linux? I am using Linux operating system and it is not easy to find compatibility alternatives. Can you give me the best website that offers a free download for this kind of applications?
Thank you.
Answered By 0 points N/A #141980
I spent hours writing a guide on how to record a screen cast, or record what is on the desktop, and convert it. I then found out that this was is much simpler and faster. More » and doesn't even involve opening the command line. In order to do this you need VLC and gtk-record my desktop. They are available in most distributions repositories. If you want to do this in Windows you will have to use a screen recording program, but the VLC step is the same.
I have had great success when using this, and hopefully you will too. As you can see I, I am running PC Linux OS, but you can most likely accomplish the same thing in Ubuntu, Fedora, and other Linux distributions. No worries. I also noticed that the video won't upload to meta cafe in Linux. I found the best way to sidestep this is to install Firefox with WINE and upload it from there. Please disregard the parts where it shows the video playing back. It actually does play back, but record my desktop doesn't capture it. If you have any questions or comments please leave them
Odom Vemus
