Hello experts,
How to download free SMS android jar?
A jar SMS file to be downloaded in the android mobile phone, is it possible?
There are some cases that I tried to download a software to make this possible, but the error says the file is not supported.
I hope you can share some ideas about this.
Thank you.
Hi Vanessa,
Hope you are doing good. I am sorry to share but android platform does not support .jar files.
It is for J2ME devices. However you can go to android market or Google play and try searching for your soft wares there.
It is a very rich software library and I hope you will come up even with a better alternative.
Or kindly share your requirements; I shall refer you to good alternative.
Hi Van!
If you search the web on how to download free SMS android jar they give limited information.
I will share with you the sites which relate your questions.
Link: Android How to download the latest zip Android Source Code easily and using it in Intellij
Link:Â How to install android applications
Just read everything in the sites so that your knowledge about it will not limit only with your question but to learn more
Thank You!
