Hello experts,
How to download gif slideshow with transitions? Or if there are no available from the internet, can you give me some instruction on how to create one for me. The software application that needs to be use and the step by step procedure on the creation process. Thank you.
How are you doing?
GIF stands for Graphic Interchange Format which enables the user to deliver smaller size of file since is being compressed efficiently.
The file has been popular also due to the developed slideshow feature.
Making a GIF slideshow is an easy process. You can download free trial version GIF Slideshow software, t and after installation, drag and drop your chosen photos, select their feature and then publish. It is very handy.
You can download the creator here.
Diane
