I have decided to buy Hi-Tech Mobile HT-11 phone from my friend. After buying that phone I want to upgrade its external memory up to 8GB. I want to know is it advisable and will it require any drivers. If drivers require Please tell me how can I download hitech ht 11 drivers?
How to download hitech ht 11 drivers if required?
Hi-Tech Mobile has recently launched technology. It supported external up to 32 GB memory by a T-Flash card slot. The device supports external memory through T-Flash card slot. T – Flash is the new format of card that is just 11mm to 15mm that is the half size of a SIM card. If you need the divers you can download from the Google search. Here is a link of hi-tech ht 11 drivers https://freeandroidroot.com/download-hitech-usb-drivers/
