How to download hp drivers series f 4000?
Hello experts,
I am afraid of hitting some downloads which is not compatible with the requirements needed to get this done.
Can you give me some ways to get a better and correct driver to be installed in my system?
Your suggestion and ideas will help me a lot.
Thank you.
Best Answer by Dawn Andarson
Answered By 5 points N/A #182778
To download hp drivers series f 4000, go to HP website. When you download it, the first and the most important thing to do is to update/upgrade your H:LIP driver. Then, choose the custom installation method, so as to be in control of the installation process.
When it gets to the end, click on the restart button. In most cases, plugins won't work but when you click on the restart button, there's every chance that the mint would locate your system, and in the process, configure it properly.
The next step is to reboot your system, log into the mint, switch on your printers, and your good to use it.
