How to download html product template and is it possible for me to connect my html program to php? Please give me some advise and website who offers a tutorial regarding this topic, or any videos will do.
How to download html product template?
There are many websites from where you can download html product templates. these template can help you find yourself making a very good html page. Take a look on these page for such downloads:
You also wanted to connect your html to php. On this issue, the following site can make a sense:
Hope these shall help you.
HTML Templates are the files that are to be published through the internet represented with a code that can be edited.
In order to make a template and make your website fully operating, you need to make your content a unique one.
The good thing is you can easily edit your HTML Templates even if you have a minimum knowledge on HTML coding since it is easily understand and can be change to convert those templates to a unique website.
You can get HTML Templates here.
And for your question if you can connect your HTML to PHP, the answer is yes it is possible using the GET or POST methods.
