Downloading the driver for your sound card is easy but you have to know what kind of sound card you have. If you have a branded computer like Dell, Acer, HP, ASUS, and others, the easiest way to get the sound card driver is from the manufacturer’s website. If you have a Dell computer, head down to Dell Support Drivers and Downloads.
PC sound card
Here, you need to provide your machine’s “service tag” which you can find on the sticker attached to your computer either on the side or at the bottom. If you have an Acer laptop, go to Acer Support Drivers and Manuals. Here, you need to provide your machine’s serial number or model number. If you have a Hewlett-Packard computer, visit HP Customer Support Software and Driver Downloads.
Here, you need to provide your computer’s serial number or product number. If you have an ASUS laptop, go to ASUS Download Center. Here, you need to provide your computer’s model name. If you are not using a branded computer, you need to know what sound card is integrated in your motherboard.
1....
