Hello experts,
How to download an intel r turbo video driver? This is a way to make a processor faster than before on an upgrade as well. But anything else I have to consider all the compatibility measurements to avoid errors during the download and installation process. I am using windows 7 operating system.
Thank you.
You can download the software on their official website https://downloadcenter.intel.com/download/26103/Intel-Turbo-Boost-Max-Technology-3-0. It is compatible with any version of windows 7. Intel R turbo does not make your processor faster but measure only the frequency of changes in your processor. It is used only for monitoring if your processor has reach its limit when running your machine.
If you are using windows 7 operating system then you need to download the relevant turbo driver. I would recommend ‘’Intel Turbo Boost Technology Driver’’ for your windows 7 operating system.
1.   To download click on this link. Intel Turbo Boost Technology Driver
2.   You can read all the instructions and compatibility requirements by open this link.
https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/6ips01ww.txt
