Mia Molly
20 points
Posted on - 09/30/2012
Hello guys,
I am a fan of drawings and other art related topics. I am just wondering if how to download an ios image tracing? A software in the ios which is capable of tracing photo images that will most likely turn it in to a real life sketch or painting and I think that was very cool. If there are some, can you tell me the process on how to get it for free?
Thank you.
How to download an ios image tracing?
There are a lot of drawing tools for iPhone found in iTunes app store, to find these tools / apps tap app store in your iPhone then click category then in the search box type the app you want.Â
On searching apps you just type what you want example when you are looking for a drawing app type in drawing and it will display all the drawing apps iTunes have with descriptions & screen shoots.
For your query I believe this is what you are looking for, in the app store in your phone type in the search box sketches & cartoon me or click on this link using your iPhone browser to go directly to the download site in iTunes.
I hope this helps.
Thank you.
