Trevor Jhon
40 points
Posted on - 09/24/2012
Hello guys,
How to download ios mp4 to mp3? This is a reverse type of converting because I need my files to be in mp3 format. And downloading ios mp4 to mp3 software is really necessary, how can I get a free download from the internet. I need it as soon as possible I hope you can help me experts. Thank you
Hi Trevor.
All you need to do is download the files and the look for an mp4 to mp3 converter.Try OJO soft video converter which is free to download from the internet and works good for me.When you are done downloading, install the program and the convert your files into the desired output format.
MP3 is an audio format while MP4 may contain both video and audio. So, if you want to convert an MP4 file to MP3 then you are not totally converting the file but extracting the audio part only. There are many programs you can use for this for free like Format Factory. Just download and install it.
Note: this is an ad-supported program so read before you click when installing because it is bundled with other programs to avoid installing unwanted applications. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Another program that can extract audio from video is ImTOO MPEG Encoder. It supports Windows XP Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10.
