How to download iPhone applications
I just bought a new iPhone 4g and I'm wondering if how can I download applications to the appstore without an apple account ?
Hi, Alden
You can download various applications for your iphone without an Apple account. There are several websites with which you can download several iphone applications. You cannot expect genuine applications from these kinds of websites. The best way would be to have an account. Some applications for iphone are only available if you have an account.
Thanks and regards,
Skarbos Jay.
Hello Alden,
I would suggest you to download apps from apple store with the apple account, which is the safest way to download a virus free and trusted applications. You can create an account without credit card option, This option is available while creating the apple account. Please follow the steps to create an account and download an application:
1- Open iTunes and go to iTunes store.
2- Choose your country such as United States.
3- Now download any free application from apple store.
This will solve your problem.
Thanks
Hello Alden,
If your iPhone 4G is on and working fine with mobile operator or wi-fi, then you can download and install. It is just a simple few taps. Now first you will get an icon on home screen named “App Store”. Tap on that and another screen will appear and there you will get an option called ”Top Free ”. Tap on that, then tap on the “featured”. Now you will get a list, in that every product will have price mentioned on the right side of that product. There will be few products you will get which will be free from those you can download. But better to have an apple account.
Also there are few websites which allow them to download apps without apple account.
Thank you,
Riley Weaver.
Notifications
