kevin rith
20 points
Posted on - 09/10/2012
How to download ipx for windows 7 for free and what is the feature of this support, what is the advantage of ipx for my windows operating system? Correct and detailed solution will help me a lot.
Thank you.
How to download ipx for Windows 7 for free?
Hello.
There is no ipx download for windows operating systems. Ipx does not support windows operating systems. If you want to have any kind of support or information you need to contact ipx support.
Click on the below link to contact and get support regarding ipx download for windows.
https://www.microfocus.com/novell/?utm_medium=301&utm_source=novell.com
Thank you.
The answer is NO.
I have try myself for this but there is no support for IPX for windows 7.
Although there are few tricks you may find on net but surly they only work on vista.
Claimed that it will work but no one replied on it as its working..
