Dear Techyv members, I would like to ask how to download irfanview tif ActiveX software effectively. What are the steps needed for this kind of download? What do you know more about this software? How is this compared to others? Please kindly include an overview and key features of the software.Â
How to download irfanview tif activex software?
Irfanview is a small and compact windows graphic viewer with multipage TIF support and multiple ICO support. In comparison with other freewares, Irfanview has many supported format for viewing and saving graphic files.
The list of supported format can be viewed here http://www.irfanview.com/main_formats.htm
A complete list of features can be viewed here http://www.irfanview.com/
Plugins can be downloaded here http://www.irfanview.com/plugins.htm, you can optionally download all plugins or only your preferred plugins necessary for your work.
What I like in its features are the batch scan support since i am using a generic driver for my scanner,
and the watermark support where you can use images for watermarking purposes
