How To Download Java 2 SE v1.6.0_01 From The Official Site.
Asked By 5 points N/A Posted on -
I want a direct link to download Java 2 SE v1.6.0_01 from the official site. Because I have to make frequent downloads to many systems. It becomes cumbersome to open the browser and download each time.
Answered By 30 points N/A #125413
It is inadvisable to download an older version as it is venerable to threats and security.
Though if you want to download and install you cannot get a direct link as Oracle requires you to accept the license agreement for preceding to download. You may use the link to agree and download the required files.
http://www.Oracle.com/techNetwork/Java/Javase/downloads/Java-archive-downloads-Javase6-419409.html
It would be more advisable to download the latest version from this link
http://www.Oracle.com/techNetwork/Java/Javase/downloads/index.html
Answered By 590495 points N/A #309436
That is a very old version of the Java Virtual Machine or Java Runtime Environment and that is not recommended because of the bugs and security holes. If you use 32-bit Microsoft Windows, the highest possible version you can install is Java Runtime Environment 8 because this is the last version of the Java Runtime Environment that provides a 32-bit version.
For users with 32-bit Microsoft Windows, download Java SE Runtime Environment 8. Here, two versions are available for download: 8u161 and 8u162. Download Java SE Runtime Environment 8u162 since this is the latest for JRE 8. If you use 64-bit Microsoft Windows, you can download Java SE Runtime Environment 9.0.4.
JRE 9 is currently the latest Java Runtime Environment and it is available only for 64-bit Microsoft Windows. You can also download the 64-bit version of JRE 8.
