How To Download Juniper Network Connect 7.4?
I am accessing the internet through my college’s Wi-Fi network, which has blocked many sites. How can I download Juniper Network Connect 7.4 to access these sites?
You can use any VPN software, such as Lantern or Hotspot Shield to access the blocked sites on your college’s network but since you are specific about Juniper Network Connect, I have listed down some links from which you can download Juniper Network Connect 7.4:
1. https://juniper-networks-inc-setup-client.software.informer.com/7.4/
2. https://support.juniper.net/support/downloads/
If you are connecting to the internet through your school’s Wi-Fi network, it is really possible that the school will block certain websites through the router because there are routers that allow blocking of unwanted websites. Since you want to use Juniper Network Connect to allow you to connect to these blocked websites using its VPN, you can use the Opera browser and install a plug-in for VPN connection.
Whether you are using a computer or an Android or iPhone Smartphone, download the Opera browser and install it. Once installed, start Opera then go to SurfEasy Proxy and install it on your browser. Once installed, follow the instructions to sign up for a free account.
Once you are ready, click on the SurfEasy icon on the extension toolbar on the upper right corner of the screen and turn it on.
Once SurfEasy is enabled, the icon will change into a green checked shield. This means your VPN is now active. You can now access the websites blocked by your school’s Wi-Fi network.
