Where can I download the Keep Alive Service for Mac OS? How can I install it and what are the key features of this program? Does it have any Pros or Cons? I need all the information for this especially if this is free to download or if I need to purchase it.
How to download keep alive service for mac os?
Hi Roman,
Keep Alive is a program that is automatically set to prevent toon(s) from falling asleep.
The Keep Alive service for Mac is not yet out though you can get one for Windows. There is another software with the same capabilities. It is called the Toontown.
This program will live your toons awake once it is running on the background. when you open the program, you will see a dog icon which indicates that the program is running. You can click the icon to see settings or to exit the program. The Toontown window should not be minimized or closed because doing so will automatically log out the program.
This program requires Mac OS X leopard, Intel or PPC.
Remember that this is just a similar program to Keep Alive because there is no Keep Alive for Mac release yet.
Below is a link to download Toontown https://danfresneda.com/ttkeepalivemac/
