How to download led light for nokia n8?
I want to download led light for Nokia n8. Tell me the website from where I can download it easily.
I am waiting for the immediate reply from the online users on the website.
Can anyone know the URL address of a website from where I can get the details of led light for Nokia n8?
I am waiting for reply.
Best Answer by Sandra R Butters
Answered By 0 points N/A #131273
Solution 1: I found this link where you can buy the led light application for n8 and then download it on your computer.
PhoneTorch N8 Flashlight
Solution 2: You can also download a torch application which is totally free by visiting the link below.
Viewing software for Nokia N8
Solution 3: Finally, you can download Flashlight Torch on this website.
Popular Games Apps
I hope this information helps you.
Regards.
Answered By 30 points N/A #131274
There are so many official websites for Nokia N8 from where you can download the led light.
The Nokia Ovi store is the most common option for this type of mobile application.
Other than this site, I would suggest you to check on the site n8fanclub for the led light.
There is also a shake light application for N8 which is very easy to use; all you have to do is just shake the phone.
You can download it from here.
Hope this could be a help.
Thank you.
