How to download lync extension for Google chrome?
Hi guys,
How to download lync extension for Google chrome? And how is this related to other browser plug ins that I usually see in the internet downloadable sites?
Thank you
Hi guys,
Thank you
You are trying to download lync extensions for the browser Google chrome. You may find many of such in the internet. Many other extensions are also available on the internet for Google chrome. Some of such kinds of extensions are given in the sites I mentioned below:
Specific lync extensions are also available on the internet. Some of them are laid in the sites here:
If you need help to install extensions, you can get help from this site:
Hope these shall help you.
Chrome does not interact with other programs.
So, your attempt to join a meeting with the Join Meeting link, it loads an aspx to search for the client outside of the browser.
aspx runs into this roadblock and fails the search and falls back to the web app.
You can try latest Google chrome version its work properly with lync.
If you want to install the Lync extension on your Google Chrome web browser, you can install Lync Meeting Scheduler. This extension allows you to create a Lync meeting and schedule a Google Calendar event. Another thing about using Microsoft Lync on Google Chrome, when you join a Lync meeting using Google Chrome, you may receive the message “Google Chrome no longer supports Lync Web App”.
This problem happens after you install the December 2014 cumulative update for Microsoft Lync Server 2013. To fix the problem, you need to install the December 31, 2014 Cumulative Update.
