How to download mac HDD icon for windows? I want to get some cute windows icon for my hard disk drive to look neater and as an indication that those are the local disks drives so that I will not be able to see them as normal disks. I hope you can help me with this.
You can try this website it has hundreds of icons available. If you can't find what you were looking for there you can just browse the web, it's easy just type in "windows icons". To change your HDD icon you will have to use this software you can find the instructions on how to use it here as well.
1....
