Brenda Lopez 20 points N/APosted on - 10/05/2012
How to download mac negative picture converter? I got so many pictures that are needed to be converted would you mind on helping me to find the best converter for negative pictures? I think there are some freeware downloads from the internet and I need your suggestion on what is the best website to pick to get some secure software.
You wanted to download negative picture converter for Mac. There are many such downloads on the web. You can try any of them. Some are good and may not give any headache to you in the process of installation and use. On the web you may find many pages and links that shall lead you to such kind of download, but most of them are affected by viruses and malware contamination and not at all safe for your pc. I tried to find some links for you that are secure. Try them:
You don’t need to download a converter for your picture if you simply want to make them appear like negatives. If you have Adobe Photoshop, it can be done there by shifting the colors. First, you need to scan your pictures to have a digital copy of every image on your computer. Once the pictures are scanned, start Adobe Photoshop then load one picture.
Convert an image to negative
If you want to convert only portion of the image, use the Marquee or Lasso tools to select the portion you want to convert to negative. Next, go to “Image”, “Adjustments” then select “Invert”. Another way is to press CTRL + I. After this, save the file with a new file name. Avoid saving directly to the original file because it serves as your backup copy.
1....
