How to download midi player Mac book?
Hello guys,
How to download midi player mac book? My current operating system is mac and I am confused on what player I am going to download which is compatible with mac operating system because it is hard to get some compatibility problem. I hope you can assist me.
Thank you.
Answered By 0 points N/A #180471
The Apple store website is the best place to get midi player for your Mac that i would recommend. You will be assured of getting a genuine player that will easily be compatible with your Mac, therefore assured of great performance. They are the manufactures of Apple products so they make available of products to compliment their PCs which is a good thing. I will give you the link for easier reference where you will purchase the midi player at a fee of $1.99, install it and you are good to go. All you need as system requirement is your Mac should have OS X 10.6.6 or later. Here is the link,
https://itunes.apple.com/us/app/general-midi-player/id498787769?mt=12
Alternatively i have found another player for you which you can also purchase and the system requirements are the same with the earlier version i have referred to you above. Here is the link
http://download.cnet.com/Sweet-MIDI-Player/3000-2139_4-21195.html
Hope i have been of help.
