How to download monthly capacity planning template? I want it in a powerpoint format and I am hoping that those free downloadable templates are editable so that if there are something to change I can do it manually.
Regards, Corey.
There are many downloadable monthly capacity planning templates, but it is not easy to find one that is in PowerPoint format.
Solution 1:
Download the template in an MS Word format. You may just download the file that I attached in this post.
Create a new PowerPoint presentation and save the contents of this document there.
Solution 2:
Download a template in an MS Excel format. Here is the link to the downloadable excel files
http://www.all-templates.biz/tags/resource-planning/
Create a new PowerPoint presentation and import the excel file that you have downloaded.
Open MS PowerPoint
Select Insert —-> Table ——> Excel Spreadsheet
Copy the contents of the Excel file that you have downloaded and paste it in the Excel sheet in the PowerPoint.
Hope this helps. Good luck!
