How to download mov format for broadcasting?
Hi guys,
How to download mov format for broadcasting? This is for my upcoming research tasks and I need some free sample from the internet so that I will be able to study and make it as a basis or reference on how I will create my own work. Can you tell me more about this and suggest base on your experiences?
Thank you.
Best Answer by Carnaje fonseka
Answered By 5 points N/A #180771
Hey Davis Millers,
You are looking for broadcasting the MOV format while this is a thing which requires you to have a specific media file (may that be MOV or not), besides, you may also like to download a software called Squeeze. The squeeze is a compression and encoding software, by using this software you’d be able to get the quality MOV format with less bytes.
I would also recommend you to download and install Quick Time codec for your project. Besides that, always try to use the full version of software in order to get the best outputs. If you face any problems, get back here with more specific information regarding your project so that you may be answered with broadcasting resolutions that is required in your project.
Answered By 30 points N/A #180772
After a quick research over the internet I found some websites offering mov format for broadcasting.
These websites are offering the software for free.
I found that the following website will help you in downloading the software.
It is easy to download and install.
Thank you.
