How can I install My Labels Premium Software on my Windows XP laptop? What is the minimum system requirements and how does it differ from any other label software? Is this software easy to use and is it easy to customized from it?
How to download my labels premium software?
My Label Premium 7 can create and print labels with professional quality. It has almost a thousand of images, photos and fonts and an easy to design tools that can help you make your work easily. You can also easily add color, rotate and align with your work. This software supports Windows 98/2000/ME/XP platforms
MyLabels Premium7 is a software program developed by the Avanquest Software company.
It is an executable file. It will install about 32 files during setup. The setup process will start automatically by the windows setup wizard. It is not available now on the Internet. You have to buy it from Amazon.com.
Main features of this product are
· Hundred of label size
· Cd labeling
· Over than 2 million images
· Over 1000 fonts
· Easiest design tools
· Built-in database
· Product barcodes
