How to download a net limiter notification?
How to download a net limiter notification? I want a safe and secure download for this application so that I will not be able to download malicious ware files that may corrupt my operating system. Thank you.
Best Answer by limasler
Answered By 15 points N/A #128582
HI Tiffany,
There is lot of net monitoring software. I’m give some of the names. You can use Kerio StaR for your requirement. It has lot of features such as identifying total traffic volume. Keep  a track of visited websites, and filtering facility. Also you can define bandwidth for each user and set the mail alerts. Here you can download the Kerio Star. http://www.kerio.com/products/kerio-control
Here is an another net limiter software. https://www.netlimiter.com  Using this it is very easy to set download and upload limits and it monitors internet traffic.
Hope this is helpful.
Answered By 0 points N/A #128583
Hello ,
I think you are searching for secured and uncorrupted net limiter software for your pc for make stronger your internet trafficking system. Here I suggested you trusted software which is uncorrupted.
Download Net limiter from cnet for trusted and secure download.
You can secure download net limiter .
Download uncorrupted and secured net limiter for internet traffic control from softpedia
I think after installing you can successfully control your internet controlling.
Best of luck..
