How to download an openoffice for delphi orientation?
Hello experts,
How to download an openoffice for delphi orientation? I am just new with Delphi and any openoffice structure or application over the internet and I need your expertise when it comes to researching of a proper and accurate download process. Thank you.
Best Answer by Xeon Ostler
Answered By 0 points N/A #165402
You can download openoffice for Delphi orientation from here http://www.freedownloadmanager.org/download/page-orientation-openoffice-delphi-5213566.html
The name of this software is Free OpenOffice to FlipBook. I have used this software, it is very easy to use and free. To use this software first of all you need to download this software. Try the above link and download the software. After completing the download, install the software. I hope you will enjoy the software.
Answered By 0 points N/A #165404
It is very easy to search for Delphi orientation for openoffice, you can type it into your search engine and can get many results, but for your convenience and ease I will like to suggest following site from you can download openoffice Delphi orientation and for subsequent installation and usage.
 http://www.supershareware.com/delphi-openoffice-paper-orientation-free/
