How to download or how to install A. tech USB keyboard?
Hello, I have a A. tech USB keyboard. I have bought it three days ago. Since I bought it for my work, I cannot set it up with windows XP. Every time I try to install it, the Windows keep trying and trying to find the driver into the windows. It never stops. Why is this happening?
Best Answer by Sharath Reddy
Answered By 590495 points N/A #185413
If that’s what’s happening every time you connect your keyboard to your computer then that only means your USB keyboard doesn’t use a generic driver which is always available in Microsoft Windows. If this is the case, the only way to fix it is to download the driver from the manufacturer’s website.
I’m just confused about the name of your keyboard because you wrote “A. tech” and I can’t find a manufacturer or a USB keyboard that goes by that name. If in case you are referring to A4TECH instead of “A. tech” then you can download the driver from A4TECH Download Support. Unfortunately, I can’t seem to find a USB keyboard on the main download page.
So, I guess you need to use the search panel on the right to search for your USB keyboard and download the driver specific for your operating system. See image.
Answered By 0 points N/A #185414
·         Install window XP service pack 2.
·         Install MIDI software driver for A. tech keyboard.
·         Sometime software cannot install because some time windows files may be corrupt.
·         May be some time downloading files may be corrupt during downloading.
·         Check your internet connection for complete installation.
·         Check your keyboard version and install software.
