How to download picasa shopping cart?
Hello guys,
How to download Picasa shopping cart? And I also want to know the proper installation of the software and if it is compatible with my windows 7 64 bit operating system which is very important for compatibility measurement. And for the software will run properly. Thank you.
Best Answer by Glover Wiliams
Answered By 0 points N/A #178507
Picasa is a free program software download from Google that allows you to position and organize all the images on your computer. It adds and edits effects to your images with a few easy clicks. It produces enormous galleries with just little clicks. It updates your Picasa Web Albums repeatedly and automatically. Download Picasa accessible to your Windows 7 64-bit Operating System here http://picasa.google.com/.
Best regards,
Heather marie
Answered By 0 points N/A #178508
Hi Bryan,
Picasa is a free software that you can download from this web site : http://picasa.google.com
  1. Click on download – a new box will be opened
  2. Click on "save the file" and browse where you want to save this file.
  3. Once downloaded, you will find an icon, you should click on it to install the software
  4. Click on " I Accept" on the new box opened for installation
  5. Then click on install – the installation will start
