How to download pocket safe apk?
How to download pocket safe apk? And what are the features of this application. Give me some website that offers a free download and of course a safe one. Thank you
Pocket apk is used for storing confidential details like passwords, bank details, and other things that you don't want to share with the world. It is very useful for people who easily forget their passwords. You may download the Pocket apk version for android from the link below.
https://www.androiddrawer.com/26582/download-pocket-2-app-apk/
If you want the desktop/computer version, you may download it from the link below. The link also contains detailed information about the product.
http://timothyjc.blogspot.in/2010/12/wallet-for-android.html
Hope this helps. Good luck!
Pocket safe is security software for your software device and it can be found and download Pocket safe.
Some of its features include:
·        Using only one password is used
·        The password is encrypted
·        The password is not stored on the phone
·        Backing up of files in a SD card
If you are referring to the Android app called Pocket that is able to store sensitive data then it is not called Pocket Safe. Pocket is an Android app that allows a user to safely store sensitive data like for example bank account details, password on your phone, and others. It is a handy tool capable of remembering all those pieces of information like contact lens prescriptions.
Pocket is nothing but security. When you use Pocket on your handset, it encrypts your data using AES-256, an industry standard encryption method. No one else except you will be able to access your data using a master password. As an added security, Pocket doesn’t store the master password locally on the Android device. The app stores it as a SHA-512 hash.
The app also allows you to automatically backup your data with your Dropbox account. Every communication it establishes with your Dropbox account is done over HTTPS. Aside from that, the data itself is encrypted so that in case your Dropbox account has been compromised, your data will be inaccessible without the master password. If you want to try it, go to Pocket on Google Play.
The latest version is Pocket 2.7 and it requires Android 1.6 Donut and higher.
