Hello guys can you give me some suggestion regarding on how to download programs for fix USB flash driver? Sometimes my USB drivers cannot detect the flash drives that I am plugging in my computer. I need your help to fix this kind of issue because I am having a hard time on sending files from one computer to another.
Thank you.
How to download programs for fix USB flash driver?
Have you check if your USB port is not defective? Sometimes your USB port is the cause why your flash drive is not detected. I suggest try http://www.flashdrivepros.com/ were they can repair you flash drive and at the same time recovered your lost files that is in the flash drive.
Try also to reformat your usb drive and it might fix the problem. some USB drives needs to be formatted before using.
Hi Jessica,
By default, Windows should have native drivers for USB flash drives and other USB devices.
Here is one way to fix this problem:
1. Go to Device Manager
a. To open Device manager, you can click on Start then click on Run
b. Type devmgmt.msc
2. You should find a category for “USB Serial Bus Controllers”
3. Under that category, you should see something that says “USB Root Hub”. There may be 3 or 4 of these.
4. Right click on each USB Root Hub and select uninstall.
5. After doing this to all of the USB root hubs, restart your computer.
6. Upon rebooting, Windows should automatically detect and install the USB devices.
You may also go to this specific link where it will instruct you how to fix problems with any USB device.
I hope this helps.
You don’t actually need to download USB drivers. What you need to download is the chipset driver for your motherboard. This will install all the required drivers needed by the motherboard which includes the drivers for the USB ports. To download the chipset driver, visit the website of your motherboard manufacturer. You may also find the chipset driver on the setup CD that came with your computer or laptop.
The chipset driver is required to be installed after installing Microsoft Windows. If you have an ASUS motherboard, go to ASUS Support to download all the necessary drivers for your computer. If you have a Gigabyte motherboard, go to Gigabyte Support. If you have an MSI motherboard, go to MSI Support Center. If you have an ECS motherboard, go to ECS Download Center.
