Hello experts,
How to download real basic ActiveX controls? Is there any download from the internet of real basic ActiveX controls? And can you give me the usage and the importance of this software. I hope you can give me some information that I need for a research.
Thank you.
How to download realbasic activex controls?
The realbasic ActiveX controls are advancement in component base development of the software. You can use the active control in your software as an independent unit. It provides you robustness and ease in the development of complex software.
Also it provides the reusability and help to customize your software. It is live visual basic components but advance in the sense it con run over Mac, window and Linux.
You can download realbasic active controls from this link.
Hello Shannon Larry,
My pleasure to assist you.
ActiveX is a programming language codes created especially for Windows operating systems and the Internet Explorer browser to run animations and other interactive data that's coming to a webpage.
After getting a small idea you can easily download ActiveX Controls from:
After a usual step the ActiveX Controls will install on your PC. After that follow the steps given below to activate ActiveX in your computer:
Click the ‘Tools’ menu option in Windows Explorer browser.
Go to the ‘Internet Option’ and select ‘Security’.
Then click on the Custom Level’ button.
After that scroll it down and go to ‘ActiveX controls and Plug-ins’.
Check the 'Prompt’ button under ‘Download ActiveX Controls and Plug-ins’.
Also check the ‘Enable’ button under ‘Run ActiveX Controls and Plug-ins’ section.
And click ‘Ok’ and then click ‘Ok’ again to save the settings.
I think now you have got some idea and it will be helpful to solve your matters regarding ActiveX Controls.
Thank you.
