How to download realtek hd dual stereo?
How to download Realtek HD dual stereo?
I want a great stereo to play some music on my laptop with an operating system of windows 7 64 bits. I hope the Realtek HD dual stereo is compatible with my current operating system. Freeware or shareware version will do.
I hope you guys will help me.
Thank you.
Best Answer by Maud Matland
Answered By 0 points N/A #182714
Hi Shanon,
Yes, Realtech HD Dual Stereo is a great program to have a stereo sound. It does support Windows 7 64 bits. Download the Realtech High Definition Audio driver from the following link –
It also supports mobile PCs. This is a shareware. Hope it gives you the desired solution.
Answered By 0 points N/A #182716
Just follow these instructions to download your High Definition Audio software.
1. Open this link. http://www.realtek.com.tw/downloads/
2. Go to High Definition Audio Codes (Software).
3. Tick the box ‘’I accept to the above’’.
4. Click on ‘’Next’’.
5. Read description and choose your driver for window 7 (64 bit).
After selecting this driver it will take a few seconds to start downloading.
After the installation you will enjoy the stereo sound.
