Hello guys,
How to download salary slip sample with editing options? Is there an application like this so that I will be able to make it as a basis and reference for my own salary slip works or if there is a way we can edit the information and save it as another file name would be much better. I hope you can help me, thanks.
Hi Curtis, i couldn't find any application which could generate salary slips but i did find some salary slips which are totally editable. Here is a link in which you will see some salary slip formats.
link: http://aletterformat.com/pay-slip-salary-slip-format/
You can download them by following steps:
1. Right click on the salary slip you see.
2. Select download button.
After download , open the file with microsoft word or some other compatible program. Select enable editing.
There you go, edit as per your requirements.
Hope it helps 🙂
