How to download software for automating ms fax? I hope there are some software for this that can be downloaded from the internet for free and can you explain and discuss with me the possible feature of this software if given a chance to get one. I wish you can give me some solution.
Thank you.
You wanted to download software for automating ms fax. This has some good versions. You can try any of them. This version is good and may not give any headache to you in the process of installation and use.
On the web you may find many pages and links that shall lead you to such kind of download, but most of them are affected by viruses and malware contamination and not at all safe for your PC. I tried to find some links for you that are secure. Try them:
http://www.passtheshareware.com/fax.htm
You may need help with installation and other things. This link may help you:
https://support.microsoft.com/en-us/help/152196
