How to download software of minutes per action calculator?
Hello guys,
How to download software of minutes per action calculator? I just want to have a latest version of calculator. I hope that it is possible to download an application like this from the internet. A freeware version is what I need so that I will be able to try it but a shareware version will also do. I need your suggestions and ideas to make things clear.
Thank you.
Answered By 15 points N/A #179181
You wanted to downloadaction per minute calculator. This has some versions. You can try any. This version is good and may not give any headache to you on the process of installation and use. On web you may find many pages and links that shall lead you to such kind of download, but most of them are affected by viruses and malware contamination and not at all safe for your pc. I tried to find some links for you that are secure. Try them yourself.
Just unzip and use the file inside. Load replays with this program. On the statistics menu, use the load button, and direct it to your replay.
You may need help on installation and other things. This link may help you:
en.wikipedia.org/wiki/Actions_per_minute
